Page 54 of 75
FirstFirst ... 4 44 52 53 54 55 56 64 ... LastLast
Results 1,591 to 1,620 of 2222
    Jan 2014
    Kazakhstan
    It turns out that the problem is that I disabled B-pyramid?
    Jan 2014
    Kazakhstan
    Even if ye include the B-pyramid & GOP is still the same result.
  3. If you do not want to have references which point to the future (in display order) then you have to disable b-frames,...
  4. DECEASED
    Jun 2009
    Heaven
    build 1.2+413-e85b0aaa64e4
  5. DECEASED
    Jun 2009
    Heaven
    build 1.2+436-ed49f875ab20
  6. DECEASED
    Jun 2009
    Heaven
    build 1.2+465-c5f2a20e6f4c
    rc: add slow first pass as option. set turbo first pass as default in 2 pass
  7. now that I released a Hybrid version were I disabled the support for fast 1st pass encoding, how ironic
    Aug 2013
    Central Germany
    You are ahead of your time...
  9. DECEASED
    Jun 2009
    Heaven
    build 1.2+471-0d4723a0080c
  10. DECEASED
    Jun 2009
    Heaven
    commit 8e45fc7=> analysis: cleanup
    commit 5a0e2a7=> rc: set rdlevel to 2 in fast first pass for multipass encode
  11. DECEASED
    Jun 2009
    Heaven
    build 1.2+496-091a63164c41
  12. DECEASED
    Jun 2009
    Heaven
    build 1.2+507-6e4eb8542203
    Aug 2013
    Central Germany
    x265 1.2+510-2bdcfcc1bb33 adds the linebreak in stats files back.
  14. DECEASED
    Jun 2009
    Heaven
    ^ Welcome back
  15. Originally Posted by el heggunte View Post
    ^ welcome back
    +1 :d
    Jan 2014
    Kazakhstan
    Всем привет!
    In x264 present OpenCL mode - allows us to expect rapid implementation of the GPU support for x265?
  17. DECEASED
    Jun 2009
    Heaven
    To the best of my memory, and unless things have changed recently,
    the OpenCL option in x264 hasn't been impressively-useful or helpful
    So I presume the MCW team will keep ignoring it for a very-long time , possibly forever
  18. Member
    Aug 2013
    Central Germany
    I was not really gone; just saw the demand of current builds well covered, while waiting for a notable change.
  19. DECEASED
    Jun 2009
    Heaven
    build 1.2+511-23d58a1819c7
    asm: AVX2 version cvt32to16_shl
  20. DECEASED
    Jun 2009
    Heaven
    build 1.2+518-d43e9a6a7cce
  21. Anyone tested the impact of '--[no-]fast-intra' on the output quality/size?
  22. Member
    Aug 2013
    Central Germany
    Don't ask for pioneers. Be the pioneer.
  23. No time and since I was interested I thought I ask if someone tested the new option and your answer doesn't really help.
  24. DECEASED
    Jun 2009
    Heaven
    build 1.2+530-d66e257ace32
  25. Member x265's Avatar
    Aug 2013
    Sunnyvale, CA
    Probably best not to presume anything on topics that you're not informed on. Definitely best not to speak for others. Although much of the work we do on x265 is checked in to the public repository immediately, other work is done in private repos until it's ready.
  26. DECEASED
    Jun 2009
    Heaven
    And hopefully YOU will have learned something from the notorious errors in the not-so-distant past of the X265 project.
    P.S.: It's very obvious that the intention of your post was NOT give a better answer to Gravitator's question.
  27. Member
    Jan 2014
    Kazakhstan
    Why DivX Player refuses to play x265 video files.... The reason for the lack of agreement on a standard decoders of HEVC participants?
  28. Member x265's Avatar
    Aug 2013
    Sunnyvale, CA
    Every HEVC encoder should create bitstreams that comply with the HEVC specification. To test this, decode the bitstream with the reference decoder (or analyze it with an HEVC analyzer). If the HM decoder can decode the bitstream, it is probably compliant with the specification. If another decoder cannot, it is probably not compliant with the specification.
  29. DECEASED
    Jun 2009
    Heaven
    build 1.2+535-3d3bc732b9e7
  30. DECEASED
    Jun 2009
    Heaven
    build 1.2+547-4c09d2ef5f1b
